ONEX #54 Web Site
Date:  1-31-2014
Manual Reference:  B04
Brief Description:  Pitch servo installation
Added anchor nuts to the pitch servo bracket. Updrilled holes in the forward bottom skin and cross member for the AN3 mounting screws. Drilled mounting holes in the doubler plate. Adjusted the connector rod length and put torque seal on the jam nuts.
The kit includes an SNX-D01-05 Canopy Latch Spring but I couldn't find a reference to that on the prints. I presume its intended to provide some tenson to keep the latch in the closed position. This would be in addition to the removable AN415-2 Lock Pin shown on D-01 detail R. I installed one end of the spring with a jam nut and blue Locktite on the exposed end of the aft slide bolt and the other end riveted into a blind hole of the latch handle, D02-13. The installation has just enough tension in the closed position to resist opening by gravity.
Pitch servo installed
Canopy latch spring
Canopy latch spring
